Having suffered MASSIVE turn in understeer on the Insight at the Auto Solo, anyone tried these?
http://www.tirerack.com/suspension/Susp ... &brand=all
Thanks, I even raced for the Williams F1 teams karting team for 5 years.Guillermo said:Mark,
No worries, the odds that lack of driver skill was the main issue was 99.99%![]()
P.g. 18-5 of the FSM PN 90117-S3Y-9000, but the range of adjustment will only be +- 1.0 deg camber (2 bolts per side required for the full degree 1 per side for .5 degree). Replace the standard upper knuckle-to-strut bolt with this thiner one to allow for .5 deg adjustment, both for up to 1 deg.Mark Elvin said:I don't suppose you have a part no for the crash bolts? 1 deg is all I am after really.
