1 - 3 of 3 Posts
Front License Plate Plexiglass Aero Cover
I cut a sheet of plexiglass from Home Depot and then used a heat gun to bend into a aero cover. Then drilled 4 holes and screwed it to the front license plate.
Not perfectly shaped but that's my DIY attempt to make it more aerodynamic :) The four screws hold it down well... I've drive in the highway at 80mph and it's solid.
Looks like a good way to draw harassment from cops.
Just move to Arizona, we don't put plates on the front of cars here.
Cops in different areas have different motivations. If you live where you get harassed it's easy enough to remove. I think this is a very cool innovation to lessen the effects of a required big flat slab on the front of your car. If we had front plates in NM I'd be on my way to Home Depot. Kudos to Dnhub!
1 - 3 of 3 Posts
