Fuel line replacement
347 Views 5 Replies 5 Participants Last post by  Paul K
Has anyone had the problem of changing the 3 rusted out fuel lines from front to back on a 2004 with A/C? It looks impossible to remove or replace due to their routing in the firewall area.
I just patched the leaking parts on mine. You don't have to follow the exact routing of the old lines, but you do need to keep them away from moving parts and the exhaust.
It was a bit finicky to get it sorted out, but after taking out the battery box/cross member and spending way too much time cursing, it all went together pretty well.
  • Like
Reactions: 1
I will have to do this shortly. I think I have a weeping line, does anyone have a supplier for stainless fuel lines? I would rather spend the money on materials and do it once
Probably NiCopp would be better than stainless. Way easier to bend and shape and doesn't corrode.
Ok i was thinking stainless because it doesnt corrode. I was hoping for above 304 SS more leaning towards 316SS. I will look for NiCopp.
Thanks for the input
