1 - 3 of 3 Posts
I don't yet have a service manual, so I can't look this up for myself.
Is there anything special about our fuel level sender? Or is it a standard "resistance" type unit? I'm hoping it's not on some kind of bus...
Thanks!
In the ESM I have, it mentions checking the resistance between Pins 1 and 2 on the connector for the Sending Unit. It gives the following values for Empty, Half, and Full:
Float Position = Resistance (ohms)
E = 130 - 132
1/2 = 65 - 71
F = 11-13
A wiring diagram of the Sending Unit shows a Black wire going to ground and a Yellow/Black wire going to the Gauge Assembly/CPU.
Hope this helps.
1 - 3 of 3 Posts
