1 - 16 of 16 Posts
Does anyone know what the actual capacity of an Insight fuel tank is?
The manual says 10.6 gallons. I drove my 2001 Insight 17 miles after the last amber light bar went out, and then squeezed in 13.21 gallons. Is there a "reserve" beyond what is indicated by the amber light bars?
13 sounds like a lot. But you might be forcing it into the various carbon filter cannisters and reservoirs that are part of the emissions systems.
To "fill" the tank, stop when the nozzle clicks off automatically.
Here's the problem: If you don't know when the tank is full, you can't calculate your true mileage. I tend to drive until the last amber light disappears. Sometimes the pump handle trips at less than 10 gallons. Once, it filled to just past 12 gallons before tripping. (That's what tipped me off that the tank was larger than Honda states in the capacities table.)
If, for example, there are 650 miles showing on the odometer and I stop filling at 9.5 gallons, the mileage was 68.42 mpg, and I'm ecstatic. If it fills to 12 gallons, the mileage was a respectable 54.17 mpg. If I continue filling to 13.25 gallons, the mileage drops to 49.06. Therefore I have no idea what the actual mileage is, because I don't know how much gasoline was in the tank to begin with.
I'll check with Honda about the carbon filters theory. They may be able to clarify the situation. If there's no harm in filling the tank to capacity, I'd rather go another 175 miles between visits the gas station.
My approach is to always use the same gas station. (You could even use the same pump every time.) Then just fill the tank until the nozzle shuts off. Doesn't it seem like that will be close enough?
I had a bad experience once when a gas station attendant did the "top off" thing and washed some gunk into my fuel system, so I'm over in the "follow the instructions" camp on this one...
G
Hi TXHondaFan:
___There is a potential to damage the Vapor Recovery HW when you actually do get one of those above capacity fills. I could never fill her to that level consistently so what I did was to average the long and short tanks to keep my FE straight whenever I did have a long fill.
___As for the range, you are going to love that part as your Insight will seem to go forever and ever :D
___The pic below is the most that I had ever filled her with:
___The details showing the few long tanks interspersed with all of those short ones …
Little Red Beauty
___Good Luck
___Wayne R. Gerdes
___[email:18eqya13][email protected][/email:18eqya13]
TXHondaFan said:
<snip>
station.
Its more than a theory. ;)
The capacity is 10.4 USG. Yes, you can overfill it. And while the fire
risk is minimal it is not zero. Do so at your own risk :!:
The biggest factor will be evaporative emissions. Of course it saves
you some time at the cost of greater air pollution. Yes, your
"contribution" will be less than the proverbial drop in the bucket. But
until we all begin to exercise the environmental adage, "Think globally,
act locally.", nothing much is going to change. Someone's gotta be
first. :D
edit & p.s.
FYI, the Insight's MPG meter has been reliably checked by many different owners to be accurate to within 2% (using OEM or equivalent circumference tires). The Civic hybrid is generally reported to be 5-7% optimistic.
The Prius also reads high. Wonder why they were not able to get as accurate of a fuel measurement in the Civic and Prius. Interesting that they are both high. But then again the Insight's speed reads about 2% high. Have fun, Rick
My suspicious nature
Just being my usual paranoid self, but I just don't trust the gas pumps to be all that accurate, unless like above post says, use the same pump at the same station, stopping at the click-off (or round up to the nearest nickel) for your mpg calculations. In GA the pumps, I beleive, only get calibrated once a year? (Anyone know any different, pipe up!)
Would ya think that maybe some stations maybe even might have pumps that were 'accedentally' a little off? Considering the outrageous oil company profits this year, in spite of all the 'shortages' and 'refinery problems', etc. :evil:
I would love to find an LED advertising marquis (sic) to put in the little back window that would light up on braking and say "Slow Down - - Save Gas --- Save Money --- Hurt OPEC --- Hurt Al-Qauida (sic) 8) You know, just to wave it at the SUV's and spread the idea.
When I was driving my Jeep Cherokee BI (before Insight) I thought 'How interesting it would be if folks would organize thru the internet a rolling boycott of the gas brands'. We can't do without our gas in the USA, but we can affect the profits of one particular company for a month. Like start alphabetically with Amoco, just don't buy Amoco for the month of January, then on to Citco in Febuary, etc. I'd bet if that knocked down 2% of the profits for that month, it would really get their attention and lower prices to reality. Course, driving an Insight now means I'd only not buy about 20 gal or less in a month, doing a 75 mile commute daily!! :D HA, with every Insight owner in the country participating, they wouldn't even notice! :wink:
http://www.jsonline.com/news/metro/apr05/317263.asp is about some monkey business in WI where they've been caught dumping regular into the hi octane tanks at the stations. It wasn't a 'enroll' type article at first.
http://www.ksda.gov/Default.aspx?tabid=51 Each state, like KA, has a weights and measures department. Be suspicious, it keeps you sharp! :p
When I was driving my Jeep Cherokee BI (before Insight) I thought 'How interesting it would be if folks would organize thru the internet a rolling boycott of the gas brands'. We can't do without our gas in the USA, but we can affect the profits of one particular company for a month. Like start alphabetically with Amoco, just don't buy Amoco for the month of January, then on to Citco in Febuary, etc. I'd bet if that knocked down 2% of the profits for that month, it would really get their attention and lower prices to reality. Course, driving an Insight now means I'd only not buy about 20 gal or less in a month, doing a 75 mile commute daily!! :D HA, with every Insight owner in the country participating, they wouldn't even notice! 😉
Your correct about the station owners monkeying to dispense less than it says on the pump as I spoke to a guy from county wrs and measures in a station one day( Indian of course,though we crackers can be just as bad) there to measure output and ask if it was a regular cyclic thing they did and he replied that it was not but only when a complaint came in. I ask if he found much cheating and he said " enough to keep me employees." You see stations may sell gas for say $4.35 g (San Jose) but they must buy it from the refinery for maybe $430 gal which means literally penny on each gal. They depend on volume and overpriced chewing gum and rip offs replacing ur muffler bearings to survive so I see their motivation. It's greedy refiners,and middlemen as with everything down to the hotel room I reserved on line yesterday and canceled 30 min later after discovering I shoulda just called the hotel and done it $66 cheaper. Online u think ur ordering from brand x but it's a middleman squeezed in that doesn't show as such. BTW My own Lil red beauty's best mileage of her life was only 67(only?) mpg and I almost always fill it to the cap for years with no adverse effects. Passes California smog Everytime. I drove,yesterday 400 miles from San Jose to LA at between 80 and 90 mph and got 46 mpg. U should see the surprised look on a Tesla when u pass at 90 mph. Shell crack 100 with myself ,the wife, and all my luggage in her, stock with 187 k on her. Best damn car ever made. Paid $800 at pick n pull as someone cast off and have put 25k on her without one dime input. Just for the hell of it I put an MBZ EMPLEM ON THE HOOD (A SPARE FROM MY 280$L) and one one each wheel center cap and a MBZ center of steering wheel one also and a big star one on the bottom back glass and consistently find groups gather around my car when leaving a store asking me what year MBZ I have .lol One guy said he was skeptical till he saw the emblem in the center of the steering wheel then he believed it. With only 27k made in 7 years few recall them. It weighs about 1850lb on the truck scale with me in it idleing. I wish I could buy one brand new. Rich
1 - 16 of 16 Posts
