1 - 1 of 1 Posts
Ok, the question is in how to best deal with this situation, the common and annoying stripped oil plug drain bolt.
Here's my situation. The car had oil changes done at a shop (usually, if not always, at a Honda dealer) but when I changed it myself for the first time, I pulled out a nice coil of threads with the bolt too. Lovely. I hopped on here to look for answers. I ended up hopping on the motorcycle (my only other transportation) and went down to the local parts store to get an M14 oversize drain plug. Worked great. Now this time, I think I may have stripped it again, even though I was being super careful.
-> Now here is what I am thinking - find/buy an M16 tap, tap the drain plug to 16mm, and then get the Fumoto F108n to put in there. Does anyone see a problem with that?
-> Would the Fumoto valve be strong enough (and the magnesium weak enough) to just cut it's own threads in the ~14.5mm hole I have now?
-> If the Fumoto valve is the last thing I am going to screw in there, do I need to bother using a helicoil/time-sert? If so, would a 14mm ID helicoil have an OD large enough that it would work in my currently oversize hole?
1 - 1 of 1 Posts
