1 - 2 of 2 Posts
Selling my '01 red manual transmission, 340 000 km (211 000 miles) I've used it as commuter car for a couple years, doing enough maintenance to keep it safe and functional, but I haven't fixed anything non-essential. I will no longer need it for work in January, so looking to sell it by the end of the year. Given the high mileage and various issues, I think it will most likely be used as a parts car or for a project. However, it still drives in the meantime. Asking 1600$ CAD, or make an offer.
83699
83700
83701
BODY
-Slight deformation of front of frame, causing hood not to sit quite flush
-Various scuffs and scratches on plastic body panels
-Large crack in front windshield
MOTOR & POWERTRAIN
-Slow oil leak from engine (never located exactly)
-Some codes related to sensors
-IMA battery pack dead (previous owner had replaced some cells but most were original)
-Manual gearbox mildly stiff going into 1st and reverse.
-Possible very slow clutch fluid leak - topped up once in the last 2 years after gearbox went ultra stiff, no recurrence since then
+1 CV joint replaced by garage fall 2019
STEERING & SUSPENSION
-Shocks totally worn out, very rough on bumps + potholes
+1 steering linkage replaced by garage fall 2019
DOORS & ACCESSORIES
-Rear wiper blad AND motor in bad shape
-Driver's window slow/jamming recently
-No power to radio since a couple weeks; probably loose cables somewhere
-A/C does not work
+Rear hatch struts replaced
+Front wipers replaced
TIRES & RIMS
Winters on OEM rims, about half the tread left
Odd sized (very wide) summer alloys from previous owner also availabe
1 - 2 of 2 Posts
