Great John. Thanks..
Do they need compression?
Honda (Panasonic?) certainly made an attempt to compress these cells, but it's not a legitimate attempt because the plastic spacers in between each cell are quite malleable. In short, I'm not sure, but if compression is required, then certainly not much is required. Fortunately, each module is already compressed as shipped. If these cells are removed from the OEM mechanical enclosure, then I'd recommend at lease some compression. In general prismatic lithium cells should be compressed.Do they need compression?
Thanks John! You're correct: --. is Morse Code for 'G'. TIL.Outstanding presentation. two longs and a short = G
I'll measure these dimensions in a couple hours.What are the exact dimensions of a bare cell please including the height to the top of the terminal studs.
I am wondering if they are short enough to fit inside a gutted G1 battery case.
Thanks
Keep in mind you'll need new bus bars if you remove the tab spacers... the battery terminal studs will get closer.I'm probably going to remove my cells from the modules based on your temperature/charging tests.
I'll repack them like proverbial sardines in a gutted OEM case as that saves a bit of weight and space!
