Hello everyone,
I bought my 2002 Insight 2 years ago with 89k miles on it, she is now up to 123000. Over the years i have used your forum to solve problems that have occurred. This answer however I could not find after hours of searching.
When I put the heat/AC on (doesn't matter which) there is a smell of gas in my cabin. Not so much when i am driving at high speeds, or even at 30 for that matter. It just happens when I am stopped or crawling in traffic. All the threads I saw that discussed this pointed to the gas lines on the passenger side of the firewall being rusted thru. In my insight this is not the case. I removed the clip that holds the fuel line and moved the rubber grommet behind which is where it is notorious for rotting out, and it is in good shape. for good measure i coated them with some por15 to keep them from rusting out. After looking at images of other peoples' fuel lines at this particular spot, I noticed they all had 2 lines coming up thru that rubber grommet, I only have 1... I dont know if that is relevant or not.
While searching in my engine bay for the gas leak i noticed that the rear passenger corner of the block is leaking oil fairly heavily (I will track down the source of this oil this weekend), maybe I am just smelling that oil which is being heated up on the block? but I am fairly certain it is fuel and it is not coming from the notorious spot on the passenger side firewall.
If anyone has any ideas please let me know what you think and i will check it out and let you know what i find asap.
Thanks!
-matt
Thanks!
-matt
