1 - 7 of 7 Posts
Earlier this week I noticed that when I shift into reverse, the gears begin to grind on my 2000 Insight (approx 48k miles). If I press on the clutch several times in succession, it appears to engage into gear smoothly. I normally only need to use reverse when the engine is cold, could this have anything to do with it?
I also noticed recently that the clutch doesn't always come up smoothly, about 2/3 the way up, if feels like it is rubbing against something. Any suggestions?
Check the fluid in your master cylinder for the clutch. It's on the firewall next to the battery.
Try shifting into 2nd before shifting into reverse.
It will go into gear more easily.
Discussion Starter · #6 ·
Problem fixed, but another question
I discovered that the clutch resevoir was almost completely empty. I don't see any noticable leaks anywhere, but can't imagine how or why all the fluid would dissapear. I've added Honda DOT-3 brake fluid and it seems to be much better.
Has this happened to anyone else? The car is past warranty so I'd hate to bring it in for no reason.
gear noise
As both your clutch plate and brake pads wear down, the fluid in the reservoirs will also get lower. How many miles on the vehicle?
1 - 7 of 7 Posts
