Hello Insighters,
I have a few questions about the heat and A/C on my 2004 CVT Insight.
I've owned my Insight for about 2 1/2 years. For most of that time, I've had the A/C set to Auto and haven't touched it (i.e. the thermostat does everything).
Recently, I started manually selecting the A/C due to some unexpected heat waves. I noticed that when I have the A/C manually selected, the heat does not work (meaning, it only cools). Switching it back to auto and setting a higher temperature, however, does engage the heat.
Is this normal? I'd never noticed it in detail before.
My other A/C question is that, my heat and A/C do not work immediately after a cold startup. If I start up my Insight, I have to drive my car for about a minute or so. I typically leave my A/C on when I turn off the car, so when I get back in it in the mornings, it's already on.
For the first minute I drive after a cold startup, nothing runs. It takes a minute or so, and then I hear a trickling sound (like water or coolant) and then the A/C kicks in.
This has been consistent since I owned the car. Is this delay and trickling sound normal? It runs fine after it's started up.
Lastly, the rubber around the antenna has dry-rotted, and then antenna wire itself is rusted. I asked the Honda dealer where I usually get my Insight serviced if they could replace it. They said that the base of the antenna was rusted and that they couldn't guarantee that they could remote it without it breaking off in the base, which would require about $300 in labor to remove if it happened.
This seemed rather unprofessional to me for two reasons: 1) because the bottom of the antenna that goes into the antenna base appears to not be rusted and 2) because it seems to me that a dealer should be able to cover their own mistakes if this happened.
Is a rusted antenna/antenna base normal? Anywhere I can take it to get it serviced/replaced without having the fear of potentially paying several hundred dollars if it breaks off?
That's all I've got for now - appreciate it!
