I have a Scangauge, and I am wondering if anyone knows how to query the car for the outside temperature sensor reading?
Frank.
Frank.
Try this: Hold down AUTO and MODE while turning on the key, and the A/C display flashes between two numbers. Press the rear window defogger (leftmost) button to advance to the next sensor.
The first number is the sensor:
1 = in car temp
2 = outside temp
3 = sun sensor
4 = engine coolant tmperature
5 = evaporator temp
6 = air mix opening %
7 = vent temp out
8 = something about the fan
9 = vehicle speed
For the temperature sensors the reading is in degrees C. If a sensor is disconnected or shorted, it displays "Er".
Dougie;Try this: Hold down AUTO and MODE while turning on the key, and the A/C display flashes between two numbers. Press the rear window defogger (leftmost) button to advance to the next sensor.
Where did you come up with that, i.e., the sensor numbers?
Fred
For what it's worth, I tried that the other day - very interesting!Just Frank said:This is described in the service manual. I just got mine and saw this too in the section about the climate control.
For $75.00 the service manual is a pretty good investment. Albeit a very hefty tome.
