Hello all. I've been lurking on these forums for a while, reading other people's posts to help fix my problems. Now its time for me to post a problem of my own.
I was reconditioning my IMA with a Prolong kit when it stopped working.
I have an IMA battery that is (mostly) dead. I've been using a Prolong grid charger to help keep it going. I began a charge/discharge cycle yesterday afternoon, following the instructions. I filled it up, discharged down to 90, then plugged it back in and let it do its thing over night. Ambient temp was a consistent 80 degrees.
This morning, I disconnect that charger, and plugged in the light bulb discharger. I turned the switch on ye olde volt-o-meter counterclockwise and screwed in the 150 watt bulb. The light bulb popped and burnt out as soon as I plugged it in. After this happened, the meter read 0 volts, instead of the 170 that it read initially. Tried other light bulbs, nothing happens. No light, no pop, not even a flicker. I unplugged the discharger from the harness and plugged in the charger next. It read a full charge (above full, actually, it showed 180), but -.002 amps. I took the charger into the house and plugged it into the wall outlet (no connection to the harness) and it gives the exact same reading, so I'm thinking that this is the nominal reading it gives when it is not receiving input from the IMA pack.
Crossed my fingers and took the car out for a test drive. Feared the worst, but it ran just fine. IMA kicked in, charge/discharge, no problems. That's great news, but I'm puzzled as to what the problem actually is.
Has anyone experienced anything similar to this? Is there a fuse in the Prolong harness that I might have blow? Did I burn up some of the wiring on the harness? Not sure what to think, and since Car Talk is no longer on the air, I figured it was time to ask you guys.
