1 - 12 of 12 Posts
My car started to make a loud grinding noise when the clutch is not pressed, when I press the clutch in it goes away, what do you think it is, clutch, bearing, motor mount?? Looking to diagnose before i have to pull the clutch, thanks.
Car drives fine, no issues with shifting or taking off, allthough i think the clutch chatters a little, 190k miles
Moderator
It's going to be the input shaft bearing. :(
  • Like
Reactions: Saxjonz and jime
thanks, I just order clutch kit, isb and seals, I will look at the mod, i dont have an issue with the grind now
Consider hch swap while you're at it. Better gears and stronger isb. Little grinding of the shaft and slight speedometer error, well worth it
Honda Civic Hybrid transmission. Has about a 10^ shorter final drive and closer spacing on 1 through 4 so if you shift at redline you stay above vtec engagement
1 - 12 of 12 Posts
