I cleaned all eight ground connections
1 Battery post ground
2 battery ground wire @ firewall
3 Transmission ground @ body
4 transmission ground @transmission
5 transmission ground @ body
6 transmission ground @ transmission
7 power steering ground @ body
8 Power steering ground @ power steering rack
I also exercised main circuit breaker a bunch of times
No more IMA light
No more check engine light
No more 12V battery charging light
Copper Anti-Seize Lubricant
torque specifications should be reduced by about 10%
I have owned my Insight Two years
The check engine light code need new IMA battery
Now the car IMA system works like NEW
Linsight Designer
I'm glad this worked for you this time. However, note that without performing an electrical resistance test, it is VERY difficult to visually determine if a particular ground strap is "good". They can look like crap and perform well... and they can look great and not work one bit.
IMA system working better than ever
fuel millage went up by 10mpg
