Check engine light just came on the other day along with the IMA light. Would love some ideas and insight. I took it to a place that said they know Hondas including the insight well, pulled a P1568, scratched their head and said I have to go to the dealer.
Known details:
1) Driver side of engine, the second (going from top to bottom) ground cable to the engine is broken.
2) Check engine light came on with a P1568 code
3) IMA light is often on
4) If I rev the engine up high, the brake and battery lights come on and eventually go off after driving for a while.
5) Driving home from the shop I wrapped the one end of the broken ground cable to the other ground cable. The IMA light went off, it charged and assisted fine the whole way home.
6) Day after, with ground wire still wrapped around other, IMA light is back on and no charging or assisting.
7) Battery is always well charged and seems to work fine.
Could this all be from bad engine grounds?
Anyone know the part numbers for those two ground cables and is there a third somewhere I heard speak of (Can't seem to find them at hondapartsnow.com)?
Any other ideas?
Thanks,
Mike
Known details:
Any other ideas?
Thanks,
Mike
