Hawker PC 545 Posts.
1527 Views 4 Replies 4 Participants Last post by  JustinGray
So i Got the battery... nice price on eaby. No posts on it though. Picked up some posts from the local pep boys... not the right size.... where do i get the posts from?
Thanks for the help.
Justin
I installed a PC535. For the ground side I just made a new grounding strap so no adapter is needed. For the postive terminal, I bought some adapters for side-terminal batteries, cut off the stud and then drilled an taped a hole. Pretty easy to do because of the soft metal they use.
The hard part was fabricating a new hold down bracket.
I found the adaptor posts at batteries plus.
batterie plus had em... thanks guys!
