My hazard flasher indicater light (telltale) doesn't work anymore though I have allready changed the bulp that is build in in the switch. The hazard flasher itself, the direction indicators and the green, arrow shaped direction indicator control lamps in the dashboard work well. However, when I switch the hazard flasher on, there is no current on the white wire that goes to the hazard flasher control bulp.
Anyone has allready had this and knows what the problem is? Could it be the flasher relay? If yes, where is it build in?
