1 - 3 of 3 Posts
Hi fellow Insighters,
Can someone post instruction on how to adjust headlight.
Mine are a bit to high and would like to bring them closer to the road and thus not anoying upcoming drivers.
Thanks.
The adjustments are made by using a Phillips screwdriver that matches
the "round teeth" . The vertical adjustment is close to the rubber piece
that touches the hood (when closed) on the metal support that runs
across the car. You will see a hole that you put the screw driver in. Be
sure you're on a flat surface when comparing left and right.
Thanks.
1 - 3 of 3 Posts
