1 - 7 of 7 Posts
Good day all
I have a problem with the climate control on my year 2000 insight.
My workshop manual says that I can open the DTC self diagnostic by pressing the fan down and up buttons at the same time.
My insight does not have these buttons, instead it has a button to cycle through the fan speeds.
So does anybody know how to open the diagnostic system on this version?
Wife is getting cold !
Bob
The "no A/C" version of the car has up and down arrows for the fan speed...
Found it thanks
Hi
Thanks for the quick reply.
Found the thread, don't know why I didn't find it before.
'you were correct, key on, press auto first, then off (both are now pressed) and hold. nothing lit up indicates nothing wrong. If you have a code the segment that represents that code will light up, then show 88, then the segment again.'
Here's from the codes html spreadsheet in sig. under the HVAC codes with links
____________________________________________________
HOW TO ENTER HVAC SENSOR INPUT DISPLAY MODE:
1. With the IGNITION SWITCH OFF.
2. PRESS & HOLD the AUTO BUTTON and MODE BUTTON at the same time.
3. START ENGINE.
The HVAC Sensor Display panel will flash values:
Advance the HVAC display [#]'s by pushing the 'REAR WINDOW DEFOGGER BUTTON' repeatedly.
To CANCEL press the HVAC's 'AUTO' BUTTON; or turn off the IGNITION SWITCH.
The [#]sensor, will display values: in [°C)]; [%]; [solar rad]; [kph].
[1] [°C] Inside Temp > [2] [°C] Outside Temp >
[3] [%] Solar Rad > [4] [°C] ECT >
[5] [°C] Evap Outlet > [6] [%] Air Mix >
[7] [°C)] TAO Vent > [8] [°C)] TAO Fan > [9] [KPH]
Er = 'error': this is caused by and 'Open' or 'Short' in the HVAC circuit or sensors
3. START ENGINE.
I do not have a/c. I do not have an auto button.
1 - 7 of 7 Posts
