1 - 9 of 9 Posts
Hello guys, I'm new with this, I prefer DIY than go to a shop, I tried to ask for quotation for the service they charge me €250.
I bought this.
I need help where I can tap the power for my device, I don't know where to tap for accessory, I located the fuse box in my 2009 JDM Insight.
What is the total amperage of your load? You are going to have to install a bigger fuse no matter what you tap in to. I would use #24 and install a bigger fuse.
Thank you so much for the quick reply. I will be using this items, still waiting for the package of the 2 items.. 20A fuse is it ok?
https://www.aliexpress.com/item/32965465274.html?spm=a2g0s.9042311.0.0.698e4c4dL6MmVb
https://www.aliexpress.com/item/32879751407.html?spm=a2g0s.9042311.0.0.27424c4dqGQlZE
https://www.aliexpress.com/item/32871314326.html?spm=a2g0s.9042311.0.0.27424c4dqGQlZE
Will be using this taps.
https://www.amazon.co.uk/KOLACEN-Automotive-Low-profile-Assorted-circuit/dp/B07DCWK1ZV/ref=sr_1_5?keywords=fuse+tap+kit&qid=1562271566&s=gateway&sr=8-5
1 - 9 of 9 Posts
