1 - 2 of 2 Posts
Honda insight 2000
I am in a dead end with my car and maybe someone has a solution !
Recently I have worked to restaure an Insight 2005 with a CVT transmission.
The compression was bad on cylinder 1 and after investigation an exhaust valve was bad and the head gasket was leaking.
Instead of repairing the head, i just changed it with another head i had from a 2002 Insight with manual transmission.
Now the car run but i have noticed that my ignition timing as 40 degrees in advance. The car starts at 12/13 and rapidly increase once water temp turn 44degree.
When this occur, the engine sounds bad (Knocking ?). It doesn't seems to be normal... As a comparison my 2000 Insight with manual trans is running 12 on idle.
Here is a list of the things i have done so far related to this problem :
  • Check MAP sensor : Working fine
  • Check VTEC solenoid (stuck open ?) Working fine ;
  • Vacuum leaks : No leak detected ;
  • Coils are new ;
  • The exhaust is free;
The timing is perfect and the pin on the cam gear is nice and in place. My compression is consistent (143 PSI each).
Am i missing something ?
update: I have ordered a ECM. I don’t know how but is it possible that programmation is bad ?
Thanks a lot for your help :)
Automotive tire Motor vehicle Gas Auto part Engineering
Product Automotive tire Motor vehicle Rim Automotive wheel system
Automotive tire Tire Wheel Tread Motor vehicle
1 - 2 of 2 Posts
