My dome light and open door sensor light on my dash have been going on and off when I hit bumps going down the road. I made sure all my doors and hatch were properly closed and seated. Anyone else had this problem, and would be kind enough to give me some direction where to look for a remedy? Thanks.
20 years ago a friend drove a co-worker to lunch in his Civic. Guy slammed the door so hard he actually bent the door post (where the light switch push button is) just enough to cause exactly the symptom you describe. The switch was now just far enough in that it didn't make a good on/off anymore. Try taping one switch down with painter's tape to isolate which switch is having a problem.
Thanks for the suggestions. I will try both.
