If the stereo sounded great, then it probably wasn't the stock stereo. If the speakers fit neatly behind the grey plastic grills, they may have been stock. Often when replaced they don't fit behind the grills any longer.
Look at the bright side, if it sounded good and it WAS actually the stock system then imagine how great it will be when you do even a minor upgrade.
The stock only has a tape player, so that is a dead giveaway that it is not stock if it has CD player or mp3 player in there... Duh! You said a CD was playing. Therefore not stock.
The little tires kind of track in grooves on the pavement. If you get used to it, then it just adds to the fun. If you don't like it, you can swap out tires to wider ones. Lots of threads on this. Always some hit on mpg, but it varies from tire to tire.
Sometimes I have had problems starting the first time from autostop, even though I have gone to 1st gear. It seems most often if I have done a lot of stop and go. It hasn't happened in a long time now, but it does happen. No real explanation.
If you were driving with AC and still getting that good mpg, that is very good. AC may make it a bit more slow. The trick is to get used to the gearing. You can go just over 70 mph in 2nd and hit the speed limiter in 3rd, so if you have a time when you need acceleration, then downshift pretty far for it.
Lean burn is 100 mpg or more. It also often sticks around 75 mpg, which is good but not lean burn. If it pegs at 150 mpg, then it is fuel cut where it cut fuel entirely.
There are lots of slower cars out there, and faster ones. You'll need to experiment with the Insight style and then you can find that it can be zippy enough to be fun and high on the mpg. You can also do the turbo kit, if you want to join the turbo crowd.
