1 - 1 of 1 Posts
Honda has just confirmed that it will build two additional hybrid models that will go on sale in Japan starting in February 2010. The first is the highly-anticipated CR-Z hybrid and the second is a hybrid version of the sub-compact Fit.
Both models will use Honda's IMA (Integrated Motor Assist) hybrid system, a less sophisticated setup to the one currently running in cars like the Toyota Prius and Ford Fusion Hybrid. Honda did say, however, that it is developing a new hybrid system, which will most likely be an updated two-mode system capable of running for a certain distance on just electric energy. That system will initially be used in mid to large-sized vehicles, like the Honda Accord.
The CR-Z first launched at the 2007 Tokyo Auto Show and now that the Insight has been introduced the resemblance is obvious. We just hope the CR-Z stays true to the fun driving dynamics of the CRX and doesn't use the out-dated torsion beam rear suspension of that the Insight uses.
Honda did not say if either model would be available outside Japan.
More: Honda Confirms CR-Z Hybrid and Fit Hybrid for 2010 on AutoGuide.com
1 - 1 of 1 Posts
