I had the oil consumption issue come up at almost 70K miles - check engine light and no oil on dipstick. Same TSB was referenced and same fix as you described. Now at 140K miles.
I've had a slight oil leak ever since - had it back to dealer several times right after and they tried to find source, replaced several gaskets, etc., but it has lingered and I've lived with it. Not even enough to drop the level on the dipstick, but enough to drip a few drops on my garage floor (and make the plastic undercover a little messy when removing for oil changes).
Other than that I haven't had any major issues. Oil changes, brakes, tires, shocks, one 12V battery, that's about it. I also just had my valves adjusted - I had noticed a slight but increasing vibration when the motor was running, pretty typical for Honda's (we also had a 2006 Pilot that required valve adjustment from time to time). I waited until 118K miles to change my CVT Trans fluid for the first time - it was filthy but has never been a problem. Some recommend changing that every other oil change but I'm likely to maintain about 50K mile intervals - even though it's really easy to change, easier than the motor oil. I have not changed the filters (one inline and one in the pan). At 140K now it still is nice and pink on the dipstick.
I've had it since new and it's always been parked in our garage. I'm likely to replace it in the next year, but only because I'm ready for something newer, more comfortable, and larger (we had a surprise 3rd kid a few years back). It's been what I purchased it for - a good commuter. I would expect well over 200K of continued solid performance if maintained.
