1 - 8 of 8 Posts
How do you disconnect the power in the Insight whenever you are doing something that calls for disconnecting the negative battery cable on a regular car?
I presume just disconnecting the negative battery cable won't do it.
Thanks!
power disconnect
The same way you would on any other car. Only after you reconnect the battery lead you should reset your MCM. It tell you how in the OWNERS MANUAL.
Lee,
I could be wrong, but I think MCM stands for Motor Control Module. Depends on what you're doing whether you want to totally disconnect the battery or not. If you need to take the negative cable off to hook something up, you can use a jumper from the battery to a ground point so you don't have to reset everything.
Jim said:
Lee,
But, Lee, wouldn't that jumper be defeating the purpose of taking off the negative lead? :?
2000 Silver M/T
I think the real question, is what are you trying to install?
I install aftermarket automotive equipment for a living, and I
never disconnect the vehicle battery for any reason.
1 - 8 of 8 Posts
