Hi Delta Flyer:
___Autostop or forcing autostop will get you far higher then 40 mpg in stop and go traffic. Pulse driving as the Prius II owners like to call it but with a few twists … Leave a 3 or 4 car length distance between you and the guy in front. Wait until he moves and when a larger gap appears, take off very slowly in first, then second
with no assist and before you need to stop again, you should have the ICE off via autostop or forced and coasting up to a similar distance behind him. On slight downhill’s, you can simply coast down the hill using a timing method although you are not timing lights, you are timing traffic patterns in the stop and go traffic jam
with the ICE off of course. You should achieve fuel economy in the high 80’s to low 90’s using this method. While driving a std. ICE, you can use the forced autostop and coast down the slight declines as well. Crawling in the flats or uphill however is a bit tougher proposition as you can well imagine
When you do start moving again no matter how slowly, you can actually make up some of your lost segment mpg’s. Just accelerate very very slowly while traffic is beginning to surge ahead and let the gaps expand and expand some more. There will be those that fill in that gap again and again from your left lanes but you will come up to their back bumpers in the next section of stop and go. You can slowly accelerate an Insight to 30 - 35 mph above 90 mpg in warmer temperatures when she is warmed up if you are very careful on the throttle. Just do not get frustrated and keep focused to what is going on in the traffic patterns for maybe ½ mile ahead is about all that needs to be added.
___Overall it is not a pretty proposition given our lightweight Insight’s could really us an all EV mode without ICE engagement but this forced pulse driving works. A Prius II running in EV mode will not achieve the fuel economy of an Insight in a stop and go traffic jam using the above technique because they pay in blood to bring that pack back to its 56% or so SoC or thereabouts afterwards. We just have to pay for the IMA start which isn’t really that bad given you might lose 2 or 3 bars after 20 minutes of this kind of behavior in a traffic nightmare. I usually sit in one of these SOB’s about 4 or 5 times a week when I am on day shift coming home
___Good Luck
___Wayne R. Gerdes
___[email:1v1w2xor]
[email protected][/email:1v1w2xor]
