Is your IMA battery dead weight? Want to remove it completely?
youtu.be/c9OZLoJG4RU
Watch this video if you're looking to:
-remove your IMA battery, &
-keep your 12 volt battery charged, &
-trick the car into thinking everything is peachy in IMA-land
Here is the latest schematic and code.
Notes:
-Battery Malfunction Light will (temporarily) come on each time you exceed ~4000 rpm... light will turn off once RPM drops down. If you don't want that behavior, you'll need to install an aftermarket DCDC converter (as discussed elsewhere).
-Standard USA EPA Caveat: FOR OFF-ROAD USE ONLY
-Both code versions are now updated to use same pinout. See new schematic for more information.
Notes:
