Thank you on the quick feedback
Hi Eli and Calpod,
Thanks for the quick replies.
Eli, I can't see my switch where I mounted it (in one of the three removable blanks to the left and below the steering wheel, right above the little door, so a lighted switch wouldn't help. It is very easy to reach, as I just put my hand toward the dash, and installed the switch where it felt natural. Also, I didn't know how much or how little voltage was involved, or if the extra load of a light would throw off the computer.
Calpod, I just took it for a test drive, and the green indicator light does not come on at all when I have the switch engaged. It does come on when the car thinks I should shift when the switch is not engaged. I wired it in parallel, and it works great. I was thinking I would like to put a little LED in one of the A/C vents, and run the wire down to the switch, but again, I don't want to screw up anything computer wise. Also, there may not be enough voltage, so it might need a 12v feed wire, and then maybe diodes.....
Shoot, I get lost in electronics extremely quickly. I can usually follow directions from people who have already blazed a trail before, and can manage a soldering pen decently, but consider myself a rank beginner in the electronics field, so I depend on you guys for help. Hopefully, I can give enough feedback later to "pay it forward".
Anyway, this was just a thought, as I have to reach down and touch the switch sometimes to remember which position I left it in. If I could see an indicator light up on the dash somewhere it would help. No biggie.
Thanks again,
Tim Glover
Hi Eli and Calpod,
Thanks again,
Tim Glover
