Hope I edited the previous topic ok, i went to move it and it said cant connect to forum.
Anyhoo, fold the seat down, get a 12 mm socket and rachet. Go where the seats butt each other and start to pull the fabric away from the hinge joint beat the seat belt bucket on the drivers side.
You should feel if not see 2 12 mm bolts on each seat half. Undo those 4. The passenger seat swings upwards then pull it to the drivers side to get the pin out of the other end of the hinge and remove. Do the same for the drivers side seat. Then make sure to unbuckle the center seat belt or unbolt it.
The bottom just pulls up once you unlatch the 6 or so connectors on it around and behind the cushion.
I have my seat back removed for more cargo room, but left the seat bottom in place. It doesnt weigh much and protects quite a few cables under it tot he gas tank. .
