Considering how much effort Honda put into weight reduction, I was amazed when I found that there is a purely decorative part on the Insight the weights about 1.5 lbs. Its the engine cover and it's mounting bracket.
It's pretty easy to remove. You'll need to replace (or reuse) the bolts on back because they hold a wiring harness bracket. The cover bracket requires an allen wrench with a bit of torque to remove. I'll been running without mine now for several months and no problems.
The 3 bumps in the cover make the engine appear much larger than it actually is. Do the marketing boys at Honda think people won't buy the car with a small engine.
To be fair, looking at the cover mounting bracket, you can tell it was not designed by the same guys that designed the engine or body.
Side story: I put my cover in a garbage bag and put it in a box in my garage. A few months earlier, out of the same box, I pulled an ashtray/cigarette lighter and a cargo cover to put on my CRX before I sold it. I put those things in the box not long after I bought the CRX new in 85. How many years do you think the Insight engine cover will spend in that box?
