OK, I got tired of reading the posts on the forum that said variations of "you can't swap the seats out because the bolts don't match." Today I busted out my tools and went at it with determination.
DISCLAIMER: The safety harnesses and seats are an integral part of the cars safety system. This post is the details of what *I did to my car*. Should you choose to attempt to do the same thing I did, you are at your own risk.
Difficulty: low
Time required: 1 hour
Modification required: minimal to none
What's needed:
- 12mm socket
- 14mm socket
- Phillips #2 screw driver
- Pliers (needle nose and regular)
- Red loctite
- Socket wrench (either 3/8" or 1/2" drive)
- Breaker bar
- Torque wrench
- Cordless drill
- small drill bit for a guide hole (1/16" or 1/8" will do)
- 15/16" or 1" drill bit (door hole bits work well here)
- Ice cold beverage and tunes optional
Step 1: Remove seatbelt bolts
On the outside of each seat you will find a 14mm bolt attaching the seatbelt to the seat behind a sheath. Slide the sheath up and remove the bolt. It will likely require the use of the breaker bar. Once the bolt is loose set the end of the seat belt on top of the shelf behind the seat. Repeat with both seats.
Step 2: Remove the seat bolts
Sliding the seat forward and back you will find four bolts holding each seat to the floor of the vehicle. Using the 12mm socket, undo all four bolts. Repeat for both seats.
NOTE: On the drivers seat you need to unclip the seat belt indicator wire BEFORE removing the seat.
Once your bolts are removed, pull both seats out of the vehicle.
OPTIONAL STEP: Wash seat covers
The seat covers zip and come off. It wouldn't be a bad idea here to take them off and throw them in the washer. Do a search on the forum for instructions.
Step 3: Remove seat belt hardware
On the drivers side seat you will need to undo a few clips and fish the seat belt indicator wire out the side. It's pretty self explanatory. Then using your 14mm socket undo the bolt holding the seat belt receiver. Again, a breaker bar might be necessary here.
NOTE: The seat belt receiver needs to stay on the side that it came from. This is because the seat belt indicator is going to always be on the drivers side seat.
Step 4: Remove the plastic from the seats
On both sides of each seat there will be two phillips screws holding on a piece of plastic. Undo these screws. Set the screws and the plastic for the inside parts aside (that's the parts that go next to the seat belt receivers). With this modification those won't fit anymore without cutting up the plastic severely. This really isn't a big deal because it will be on the inside and you can't actually see it anyway.
Step 5: Mount the seat belt receivers
OK, for the seat belt receiver that was on the left of the passenger seat you need to just bolt it straight up to the left of the formerly-known-as driver side seat. You will need to break off a small metal tab on the receiver near the bolt but it's quite easy to do since the metal is strong but not malleable. Use the pliers for that.
Now on the seat that used to be the passenger seat you need to bolt on the drivers seat belt receiver to the right side. You should fish the wiring through the seat in the opposite fashion that you pulled it out of the other one. THESE SEATS ARE IDENTICAL, so if you didn't break the clips when you removed the seat belt indicator wire then you can actually clip them in the exact same place on your new drivers seat.
IMPORTANT DEALER TORQUE SPECIFICATIONS: 24ft.lbs for seat belt receiver bolt and don't forget the red loctite
Step 6: Mount and prep outside plastic covers
OK, this is the only real modification that needs to be done, but it looks OEM so don't worry about it. Take the outside plastic from the former drivers seat and screw the two phillips screws into the seat. There is one screw that will use the hole that you had plastic on before and the other screw uses a pre-drilled hole (presumably for the Japanese version) but you may have to slowly self-tap the screw as you screw it in. Once you have the plastic in place you'll notice that the hole for your seat belt bolt is not in the right place.
Using your drill and small bit take your finger and feel out where the center of the hole needs to be then drill your pilot hole. If it's not quite in the right position then drill another pilot hole until you get it exactly center to the bolt hole. Don't worry if you have to drill a couple holes since your larger bit will drill those out anyway.
Once you have your pilot hole, take your drill and 15/16" or 1" bit and use the pilot to drill the correct size hole at high speed (don't push down hard while your drilling it but let the bit do the work). You'll end up with a hole in the right place with some frays on the edge of the hole, but don't worry because this won't be visible when you put the seat belt bolt in
Step 7: Attach the seatbelt
Just as it says, use the torque wrench to install the seat belt to the seat.
IMPORTANT DEALER TORQUE SPECIFICATIONS: 24ft.lbs for seat belt bolt and don't forget the red loctite
Step 8: Install the seats
The seat rails slide independently of each other so when you set the seats in their place if they don't line up just lift the lever and manually push each rail to where it needs to go.
Tighten down the two front bolts first and then the two rear bolts. Repeat for passenger side seat.
IMPORTANT DEALER TORQUE SPECIFICATIONS: 16ft.lbs for seat bolts and don't forget the red loctite
Now you have the seat levers where they should go!
Difficulty: low
What's needed:
- 12mm socket
- 14mm socket
- Red loctite
- Breaker bar
- Torque wrench
- Cordless drill
