1 - 20 of 65 Posts
OK Larry, need advice. Was out testing my new FAS circuit this afternoon. Near perfect conditions here in Richmond, except for the hills of course. On the interstate, target 50 MPH, was getting 118-120MPH - no MIMA. Good, but not in your league:(
I have a question about best way to reengage LB after a hill or purge. I have been giving it just enough gas to light 3 bars of assist, then easing up. That "seems" to reengage pretty quickly, but I honestly don't have anyone here in Richmond to talk it over with, so don't really know. What is your method of reengaging:confused:
Those numbers look about right for 50 mph. As for getting back into lean burn, if it is just a normal purge event, in most cases it will automatically go back into lean burn. I usually do what someone on here suggested when lean burn drops out at the beginning of a purge, and that is to drop back on the throttle a bit until lean burn returns. I try to keep the mpg as close to 100 mpg as I can while it's purging.
As far as reengaging after a hill, that can be a little trickier. I will drop back on the throttle enough to get the FCD to read 100+ mpg and it usually reengages fairly quickly. I usually do the throttle drop fairly quickly to avoid losing too much speed...and then pray the next hill doesn't come along too quickly.:p One thing the Right Lane Cruiser told me that is helpful, is if you are ascending a hill and it becomes apparent that speed will drop below 50 mph, dropping to 4th before going under 50 mph will usually allow lean burn until you can reach the top of the hill and level out again. Of course, this is assuming you are in the far right lane of the interstate when letting the speed fall that far.
I'll give that technique a try tomorrow. I think I am definitely losing a bit of fuel with the press and lift method.
Yeah, he told me that also, but I must say that I still don't really have the timing exactly down pat, along with the judgment. Some hills one can ascend in 5th without dropping lean burn, some hills will slow too much and drop LB. One has to look a long way forward and judge the hill, along with the current speed and deacceleration. AND, here in Richmond area, some of the hills are steep enough to hit the FAS button. That really makes the MPG sail. I still need practice:)
Thanks for the tips.
Jim,
I use FAS most of the time, except in the winter, so I have a lot of experience with it.
Before arbitrarily FASing however, you need to ask yourself "If I FAS now, how long can I maintain it?"
I am not sure the exact reason (*1), but if I FAS too often and especially over a short distance, sometimes my mileage will go down rather than up. This is because once I start the engine back up, it seems that it takes a while for me to reach lean burn again. Sometimes as long as 15 seconds or so.
So the question becomes, "Do I FAS with the engine on and have immediate lean burn when I engage a gear, OR do I engine off FAS, and risk more time without lean burn". "Is the distance long enough to make up the difference?".
Good question, and I don't have a real good answer for you.
(*1) My guess is that the O2 sensor has something to do with the long delay to get lean burn again. Maybe it has to warm back up after shutting off the engine?
Jim.
Hi Jim,
Yes, there is definitely a strategy to FASing. As you say, it takes a while for the engine (o2 sensor?) to recover and one has to anticipate that. I also find myself mentally calculating whether I can stretch 5th and retain LB, or do the downshift and reengage while going uphill. For most hills, it seems best to do the downshift and reestablish early before significant momentum is lost. Hill length and grade also has to be evaluated before hand to get the best FE.
I think the whole thing becomes kind of an art. At least it is very complicated mental arithmetic that one has to work out rather quickly. It definitely helps to know your route and I think that is one reason that folks who commute the same route each day do so well, particularly with MIMA and a charging station. MIMA can be hugely important in nursing LB, but the battery is small so even here there are tradeoffs.
Fun stuff:)
I'd rather stay in 5th gear out of lean-burn and carry up the hill between 50-60mpg versus raising the RPM and going into lean-burn. You'll be pumping less air that way and still maintain a high engine load. By dropping to a lower gear and trying to hold lean-burn you are pumping more air and then using lean-burn to raise the engine load again. I've tried a bunch of hill climbs at about 65mpg without lean-burn in 5th gear and with lean-burn in 4th gear and I come out ahead in 5th gear but can get more power in 5th gear at 60mpg than I can in lean-burn in 4th gear. I'm not seeing the point. Remember lean-burn is there to raise the engine load and make more use of the air you are pumping. If the CVT wasn't so lossy we'd probably be in about the same place as lean-burn but having the CVT pull us down to about 1400RPM at 60mph or so and then raise the RPM as throttle input requires. The CVT Insight unfortunately runs the engine too fast to keep engine load high enough to be more efficient than it is.
Since it's the first O2 sensor that determines mixture, and that one is basically mounted on the exhaust manifold itself, you are going to have to FAS with the engine off for a very long time before it would cool down enough to effect mpg. The main thing is to determine if the FAS will be of a long enough distance to overcome the fuel that was burnt getting up to the speed you started the FAS at.
For me anyway, the 4th gear option works best. If I'm in 5th out of lean burn, the mpg is around the 50 mpg range. In 4th in lean burn the mpg is in the 70-75 mpg range...despite the higher rpms. YMMV.
Just a suggestion;
Install a vacumm gauge in the system and use the readings for a "guide".
8"-19" readings work for me.
It's easier to understand the gas pedal pressure also.
LB hyper miling
Grit your teeth and hold throttle pedal in the same constant position once in LB, changing throttle position upsets all the settings which takes LB time to recover.
The best hypermilers are the ones with greatest tolerance of muscle cramp in the right leg
I've got a question about acceleration, I notice there is a pretty specific point at each RPM point where the ignition timing will drop back severely. When I want to accelerate at a decent speed I've been curious lately if there is a certain point in ignition timing that I shouldn't pass. It seems that Right Lane Cruisers recommendations, which don't include engine load or ignition timing of accelerating 25-35mph in 4th gear at 50mpg for a FAS put ignition timing in the low single digits but holding 50mpg from 35-40mph is closer to 10IGN on the Scangauge. I figured that 10 would be better than 0 but of course engine speed has a factor in how fast the piston is moving and that relates to the combustion process occuring at a specific point. I know I've read about not going below 7 in the past on this forum but only one person said it. I usually try to keep above 10IGN which usually means 55mpg and slowly adding throttle to 50mpg at about mid-30's MPG and continuing to add throttle if I go past 2000RPM. When I need quick speed usually pass in 3rd gear and getting past 3000RPM you can really dump in the engine load at 90LOD and be still be higher than 10IGN. Any thoughts on that?
"The best hypermilers are the ones with greatest tolerance of muscle cramp in the right leg" Plenty of truth to that, I've taken a 1900 mile (each-way) trip and will be doing it again at the end of next month. I might forgo lean-burn and hold the 75mph speed limit though to save on the hotel stop. I got pretty lucky on the final leg of the trip home the last time though, managed 65-75mph driving in lean-burn consistently in the flat parts of the trip. I never get that driving west up the "tilted table" though, also prevailing winds usually travel east which makes that tougher too.
I constantly monitor the "Timing" on the OBDIIC&C gauge. I seldom let the timing get below -0 degrees.
Remember, due to the offset of the bore on the Insight, at anything around 0 degrees, the "mass" of the crankshaft and related items are already 12 degrees past TDC.= less load on the engine.
When assist is applied, the timing instantly goes to (-).
You can get get decent acceleration at +6 degrees.
Best is +10. This is around 3200 RPM for max. assist and timing........as that is where my car is the happiest.
(My opinion)
HTH
See if you have any luck with this http://www.insightcentral.net/forums/modifications-technical-issues/23492-much-lean-burn-you-want-2.html#post244727
YMMV of course... and because the variables of the conditions can change soo much ... I don't always do exactly the same thing day to day , even on the same route.
More so than 4th or 5th .. For me at least ... in addition to general momentum conservation ... I try to maximize net time in LB ... under some conditions that might mean 5th LB @ ~90% Load ... other times climbing a long hill or slower acceleration I might be in 3rd and LB @ ~80% Load.
If I have a high IMA SoC , I might use MIMA to hold LB in a higher gear like 5th , under conditions where I would not do so with a lower IMA SoC.
I try to generally avoid any significant amount of time at less than 60% ICE Load ... depending on the conditions , I'll either FAS , or use MIMA to add regen load on the ICE while in LB ... or depending on RPM and speed , I'll might up shift to get a higher load ... but I usually try to avoid much bellow 1,500 RPMs, or Much above 2,500 RPMS...
If you need the power, v-tech above 3,000 has a bump of it for you , but the hit it costs to ICE efficiency ( MPG ) is very drastic ... a large price to pay... If I use v-tech I know it isn't for Efficiency or MPG ... it's for something else.
And once in a great while , just for fun ... after a grid top off I might enjoy a little MIMA-EV , mostly just for occasional fun for a few blocks or so ... but , I usually prefer to reserve the IMA Energy for avoiding lower efficiency ICE conditions.
Discussion Starter #15
Discussion Starter #16
This has always been one of my favorite hypermiling stories. Some of the original hypermiling greats - some still with us here. I've read it many times and always enjoy it.
I'll love to have that kind of hypermiling terrain around here. Have done a bit in the rice roads of SW Louisiana. That is a pretty awesome environment also;)
Although I use to FAS the old fashion way by shifting to nutral and keying off I got my better mpg by working the throttle in the gen 2 to the point where it did not assist or regen.
This way the IMA stayed in check and did not do a negative recal while coasting for a few cycles.
Discussion Starter #18
I had been doing the key off routine also, but I finally realized that there is a problem. While your key is off, waiting for the fuel injectors to quit, you are racking up unrecorded distance, hurting your hypermiling results. A FAS switch doesn't stop the counting of distance.
Jime, if your meaning you have a kill switch on the fuel wire? If its Taken from the fuse level it's a 1/2 secound instantly kill, don't know why it's so fast, (pop the fuel pump Fuse when running to check ) so I broke a fuse and attached a wire with a fuse in line and kill switch,
And if you need a start switch a simple eBay 20 buck push button lighted switch works great, also using a 3" PVC pipe about 2-1/2 long caped end,right across high. Engine bay, will give you about 8 break pumps vs 4. And a vacuum pump complete the system the higher you keep the vacuum the better the mpg.
Can't beat engine off to get back mpg lost in traffic twice as fast.:)
Discussion Starter #20
I have Mike Dabrowski's FAS circuit which cuts off the fuel injectors. Can't see how anything would be faster than that. I like his FAS circuit because it does all the things the car does in normal autostop: restarts automatically on gear engagement, starts for low brake boost, fails to FAS when the IMA is low. Haven't measured the response time, but that wasn't my issue anyway. I was concerned about the unrecorded distance when using the key-off method. Should have a "slight" impact on recorded MPG;)
1 - 20 of 65 Posts
