1 - 3 of 3 Posts
I just replaced the 12 volt starter battery yesterday since it's been over 5 years since I bought the last one...
The IMA battery appears to be fully charged now. The issue is that the levels aren't going down. I went up and down some hills and the Battery recharge and assist lights seem to function fine. There just hasn't been any change in the bars of the IMA Battery level indicator at all. Did I do something wrong when I unhooked the 12 volt battery to replace it?
SOC indication
That is normal when you reset the IMA. After you drive it for a while the BCM will re calibrate and the gauge will read right.
Thanks for the detail! I just sold it to a friend and was a little worried about that.. =)
1 - 3 of 3 Posts
