1 - 3 of 3 Posts
I have found a 04 civic hybrid that is getting parted out.
What parts would be interchangeable between an 02 insight CVT in the IMA area
Pretty sure from what I have read the actual battery sticks can be interchanged
Cant find much information other than that.
What about the big fuse and any other IMA parts?
Has anyone researched this?
Also 06 to 02 the three ECM units in lower passenger floorboard interchangable?
Probably some of the below IMA stuff but minor hacking might be needed.
Main Switch?
Main 100A fuse.
DC-DC Fuse.
Battery current sensor.
Thermistors inside battery.
Contactors?
If the HCH has a manual transmission, you might want to pull it if the yard does not want too much for it.
A few of us have swapped that transmission into G1 Insights, so you might find a buyer for the transmission.
1 - 3 of 3 Posts
