1 - 8 of 8 Posts
To add insult to injury...
So a few days ago I was coming home in my 06 Jetta TDI, and it started acting funky, long story short the cam failed which is a common problem. So i've been driving my 00 insight the 150 mile round trip commute in the mean time.
About 2 days ago, on the way home, the IMA light and CEL pop on, and I no longer have any assist or regen. I figure it's just time to rebalance the pack, so I park it when I get home and plug in the grid charger.
Next day (yesterday) The battery indicator on the dash is only half full, I still have no regen, and about 20 minutes into my commute the pack shows that it has 2 or 3 bars left. At no point during the drive did I see on the dash any indication of assist.
So, I flip my switch that turns off the IMA (previous owner installed it, not entirely sure what it does but i'm assuming it just opens the circuit) and drive it as though there were no battery. Throw the grid charger on it again last night to see if that helps any.
I wake up to a full indicated battery, but the IMA/CEL lights are still on, and about 30 minutes into my drive with the ima toggled off via switch, i've completely drained the displayed battery gauge. There's no bars on it.
Take it to the parts store to see if I can figure out what the CEL is, and they can't connect... So i'm at a loss here.
I've got it hooked back up to the grid charger, since I noticed today that it was a little harder to start without any of that battery, but I don't really know what I need to do.
roughly 280k (No clue since the trip button is broken), regular oil/filter changes, battery pack was replaced in 2013 if my memory serves me correct.
Thoughts?
I didn't see where you reset the codes. Either pull Fuse #16 under the hood (tall pink 30A one) for a few seconds, or disconnect the 12V battery. Then your SOC will be zero until you drive it around a few miles. Then your ASC will be accurate and the IMA and CEL lights will be gone.
Step one with any IMA light or CEL is check the codes. You have no idea what you're dealing with otherwise.
Simply turning off the master switch generally isn't adequate to bypass the pack. There are connectors you have to unplug as well, or you don't get 12V charging.
The way you describe it, I get the impression that the car sits a lot - really bad idea - great way to kill a battery.
Before you reset the system, blink the codes (link in sig), so at least you know what you were dealing with.
If one auto parts store can't get the codes, go to another. They all have code readers. Then use the procedure in S Keith signature to read the blink codes off the dash lights. It only takes a paper clip, a flashlight and a few minutes.
Do you do your own auto tinkering? Do you have a socket set and a wrench set? How about a multi-meter?
As S Keith said, you have to do more than just turn off the switch, you have to take off the IMA cover and unplug a couple of plugs. Otherwise, no 12V charging and the car will eventually stall on the road, particularly if the battery light on dash is on.
If you take cars to repair shops or dealers, you may be in a rather bad situation with an Insight.:(
Sounds like OP is talking about a 'calpod' clutch switch when he mentions "flipping a switch" to disable the IMA...
1 - 8 of 8 Posts
