1 - 12 of 12 Posts
Any tips or suggestions/ links to replacing the fan? Went to grid charge had no noise and stopped. Pulled the cover off playing with the wires the fan would hardly run then stop. Looking for smooth and easy replacement possibly more airflow.
Thank you & by the way your guys rock my 12v died and read the forums to troubleshoot was back on the road shortly.
Are you sure it is the fan?
If it is not working with a grid charger, what power supply is it using?
Have you tested the fan with a known good 12v power supply?
Wiggling wires and it working a bit indicates some other problems.
Sounds like a loose or bad connection.
Thank you
The IMA was replaced & I asked for the grid charger to be rewired in during the process which supposedly it was. When the fan didn't kick on connected to grid charger had to stop until I get the fan running. Yesterday trying to reclip both wires ended in cutting both wires to fan. Now the length is shy so will zip by and get new connectors (& wire). Will using a portable battery jumper substitute for as 12v power supply (learning ...) to power the fan? What I noticed was the thickness of the grid charger wire was 18gauage ish and the fan is like 12 so in the connector ( clip on ) there could have been play= not a great connection. The intermittent on did surprise me so it may just be the wires need a more solid connection. Appreciate the responses.
What voltage do you read on the 12v output of the charger with the charger harness not connected to the charger vs when it is connected to the charger?
What is the current rating of the 12v fan supply in the charger?
IMA Fan & rewired it more of the same
I rewired the fan & connected the grid charger and pretty much more of the same.
The fan would intermittently run for a very short time frame.
If i hit the top of the fan it would sometimes run if I spun the fan same and other times would try to go but its like something inside is holding it back.
I called Walnut Creek Honda and they want $225 for a new fan & four days to deliver.
I am thinking to either swing by Fry's and snag a computer fan and see if it runs hooked up are there specs & sizes in a thread others have used?
Is there a thread for replacing the fan and or upgrading it?
The grid charger showed 385 when connected.
Thank you in advance
I just replaced mine yesterday at the Mid-Atlantic Maintenance day. These fans do go bad. When I had the covers off the IMA compartment, I hooked up the old fan directly to 12v, just to be sure it wasn't a connection problem. The fan jittered a few times, then stopped.
For what it's worth, here's the fan I replaced it with.
https://www.ebay.com/itm/400949545920
Any replacement you buy is going to need some cutting and filing to fit in the fan shroud. A Dremel is handy for this.
Try running any higher current rated computer fan that you have on the grid charger 12 volt power supply. If a computer fan doesn't run then the grid charger is the problem. Make sure the polarity is correct.
Google & youtube search is the place to start. And you'll get a preview of the mods you have to do to a normal fan to use in the IMA.
385 WHAT? Amps, volts, resistance????
You are just repeating your bruit force method of trying to get it to run apparently without doing any testing to answering the critical fan voltage/current readings.
You will find modifying a high current fan to fit in the IMA battery shroud to not be an easy and quick job. And some of them ended up sounding like "leaf blowers".
Discussion Starter #10
IMA fan reply
Appreciate the thoughts.
My multimeter had a ripped wire so ordered a new one = couldn't get a read.
I have a local source for a used IMA fan.
385 was what the grid charger was putting out connected showing zero not connected.
Appreciate the tip with checking if its the grid charger didn't think about that.
Assuming the grid charger was turned ON for each test this seems to say the grid charger is out puting zero volts but can read a G1 IMA battery voltage of 385 VOLTS ! This sounds more like you have messed up grid charger
Check the easiest thing to check first. After that start digging around and find out what the problem really is.
Most electronic problems are power supply related.
What kind of G1 battery are you running that has 385 volts? 385Vdc won't just shock you it will grab a hold and take your finger tip OFF.
Discussion Starter #12
The fan is swapped out and now we are in the 1st discharge cycle ( yes was charged 1st)
The extra juice read was my energy combined with the IMA without an expresso.
Thanks for the suggestions & help it's always good to get a different read as we zoom in vs out to see the whole picture.
1 - 12 of 12 Posts
