1 - 11 of 11 Posts
Just picked up a 2010 Insight LX last week and I LOVE IT! It has 160k on the odometer. This week it's been averaging 46-48 mpg in eco mode and driving very conservatively.
The other night on the way home, having it at very easy throttle accelerating slightly uphill for a mile or two in eco mode, it used all its battery, and went into a charge mode. After charging for another couple miles it seemed like it kicked off the battery (I'm assuming a overtemp issue). When it kicked on, it gave an IMA and check engine light.
When I got home and restarted the IMA was off but the check engine was still on. The assist and charge went back to how it was before.
I read the code, and it threw a P0A7F code, which seems to be a deteriorating battery pack. Definitely a bummer as I've had it for a week. I cleared the code to see if it would come back on.
Today I drove it 170 miles In normal mode and the light never came on. Three times on the drive however, it seemed like it went into a charging mode because the battery ran out. I'm not familiar with the car so is this normal? My mpg stayed about 45 mph. I drive very conservatively.
Let's assume the battery is on its way out.What are my options? It doesn't seem like there are many batteries available yet. I am also very comfortable around high voltage(maintenance tech) and wonder if the savings would justify my doing the work myself. The car is financed, so I've got to try to keep it as economical as possible.
Next week it's going in for the airbag recall and software update.
Any advice would be appreciated.
Discussion Starter #2
Also, upon some reading I see that this issue may be resolved partially by the software update, and a full discharge/Recharge to erase the memory effect on the battery
Engine-Off-Coast
Yes, get the software updates. There should be 3 software updates for the car.
Call a Honda stealership and ask them if they can check your VIN for any recalls. They will probably tell you roof moulding, IMA software, and Takata airbags. Bring it in, and ask the service advisor specifically about having them check the IMA system for any software updates, and if there are any, to apply them.
One of the updates is a recall update and they have to do it for free. The other two updates, most users here (including myself) seem to have been able to convince the service guys to apply the other two optional IMA software updates for free. You really want all 3 of them.
Yep, I have an appointment Wednesday for the airbag recall and the ima recall update. Do you have the update # for the other two updates.
What I wonder, will the updated battery management system be able to repair any battery memory, or will I have to get a grid charger/discharger to fix that?
Also, when driving normally on moderately flat roads, how often do good batteries go into "battery low force chargng"? In normal circumstances I imagine the new software would manage the charge more moderately
keep driving the hell out of it ... sometimes the battery gets lazy and sleepy if it sat for awhile b4 u bought it ... it might come back after a spell of regular use ... and there are plenty of options for replacement batteries if needed - dorman, ampedhybrid, and bumble bee .... i saw a youtube video of the swap and it doesnt look too hard at all ... b aware that a faulty 12v battery can make gremlins appear so if its on its way out just change the damn thing ... u can upgrade to a 51r which is more robust and has greater longevity ... best
I had the dealer replace the 12v as a condition of purchase. It did sit I think for almost a year before I bought. Should I be driving it more aggressively in normal mode to do big charge/assists to revitalize the batteries? I've been light on the throttle and sipping gas this week
There is a very good chance that the software updates will fix your issues. Many years ago, before the software updates were official, we had threads from owners who had similar check engine lights at much lower miles. At the time Honda was having the dealers apply the updates and see if the codes came back. Mostly they didn’t. Hopefully you can make it through the next few days until your dealer appointment. Do have the dealer load test the 12 volt battery, even though it is new. Wouldn’t be the first new battery that has issues. Try to not freak out, as any hybrid that sits around too long will have these issues. So far, based on reporting around here, most revive. In fact I don’t remember any dead IMAs that were not the result of a rear end collision. Even then it was damaged electronics, the battery pack itself was ok.
That gives me such relief. The IMA was a big fear in purchasing. It makes me happy to know the system is robust enough to revive hopefully. My partner will be taking it in Wednesday. I took it out today in sport mode, just for fun.
Discussion Starter #9
I took it in today for the update and it's like night and day. The recharge cycle seems to make more sense, and the battery seems like it can give more assist for longer without going into recharge mode.
1 - 11 of 11 Posts
