1 - 11 of 11 Posts
2001 Honda insight CVT
So, every now and again my IMA light comes on (usually after I'm on the highway and using the assist for extended periods of time) and I know I have to get the codes for you guys to be of more help BUT, I have realized I can make the light go away and everything function properly (albeit temporarily) by undoing the terminals from the engine battery under the hood up front, leaving them unhooked for a few hours, then hooking them back on. I'm good for a few weeks or months after that then BOOM back on again.
Rinse. Repeat.
Anyone seen a 2001 CVT insight do something like this? Anyone read this and immediately go, "oh yeah you're in trouble" or "oh yeah, sounds like this. You should do this."
Or do I really just need the codes read for a good answer.
Let me know! Pic for attention and reference I guess
90105
It's time for a grid charge.
Alright I've been planning on buying one from hybridautomotive when I'm able too, this is LIKELY the issue and should help me out a ton, right? I've done a lot of research and thought this might be the answer (it seemed too simple) but if it is then cool
We need the codes for accurate advice otherwise we are making educated guesses..
Sam is probably quite right but... Get the codes then we can be sure..
Can I just go to AutoZone and they run codes like any other car? I know there's a specific code reader a lot of people buy for gen 1 insights so they can get an accurate read on the battery but is that overkill? Can I just.. go to AutoZone and let y'all know what comes back?
You can try an automotive store or two for a free read of codes. Some store seem to recover the basic IMA codes, while other seemingly can't. After all, it's free. Once you get the codes, you can use a paper clip at the OBCII plug to trigger the subcodes.
If you are looking for an inexpensive charger/discharger, why not look at this one:
At least you get an inexpensive one and you don't have to fight MaxxVolt to get the discharge capability.
I have no commercial interest in RB Battery, nor have I tested their product, but others on IC have.
Discussion Starter · #8 ·
If I get this one, may as well go out and get the one from hybridautomotive, MAXXvolts is just under 160$ by comparison to the 350 here and 409 at HA. The MAXXvolt one I could buy fairly quickly.
Discussion Starter · #9 ·
How necessary is discharging if my battery still functions? I've read a lot of stuff that says discharging is only truly necessary aside from grid charging when the battery is on his last leg. I can still get this thing to work by removing the terminals from the front battery and then reattaching them after a few hours or so for some reason.
Even without a code reader, you can pull flash codes with nothing but a paper clip.
1 - 11 of 11 Posts
