I live in Mauritius,Possibly but we need a lot more information.
Can you video the behaviour and upload to youtube?
How hot is it where you live?
The weather is not an issue.
The car is chewing fuel as if am not driving an Hybrid car. The Km/ L range dropped drastically, usually the car should do 18-22 km/l when its good, but most of the time its 11-14km/l.
While accelerating the assist gauge goes to high peak when the car is good. When the car drives rough the assist gauge go only half. I need to accelerate more to get it on high peak.
That are the symptoms
To note that the battery is new, i have checked with the agency, the battery is good.The IMA battery may be bad/weak or out of balance.
I suggest you do the cycling/balancing procedure outlined on the CR-Z forum. (It's the same battery pack as G2)
Nimh IMA Battery. Rejuvenation Procedure....
A detailed walkthrough on how to charge/discharge and cycle your old lazy CR-Z/Insight G2/Jazz Hybrid Nimh IMA battery to restore some performance? It's a well established relatively inexpensive maintenance technique used successfully for many years on the other Honda Nimh IMA cars. I'll do a...www.crzforum.com
I have replaced it at a hybrid care garage.The IMA battery has been replaced?
When and by who?
Was it a brand new OEM battery or aftermarket? Brand?
Have you ruled-out other ignition issues? How many km do you have? When was the last time the spark plugs were changed?The car is chewing fuel as if am not driving an Hybrid car. The Km/ L range dropped drastically, usually the car should do 18-22 km/l when its good, but most of the time its 11-14km/l.
