I have a 2000 Insight with a battery level indicator that will not drop below about 80% charge. The IMA does provide assist when I step on the gas but because the battery level is supposed to be almost max, the system won't charge the battery pack except when regen braking or when coasting down a hill. Since the battery is not being charged adequately, when assist is required the battery can only provide a limited boost for a limited time-usually not enough for even a short hill- but the gauge continues to shpw 80-90% charge. The actual battery level can get so low that on a few occasions on approaching a stop & depressing the clutch, when the car tries to switch the motor to standby mode, the car stalls instead. When I then restart, it takes a couple of seconds & then I hear the starter turn over(not the IMA start),the car starts & away we go.
Forced recal makes the problems totally disappear for about 5-10 minutes as the charge system rebuilds the battery level. However, when the charge level gets to just over half, the charge gauge moves quickly to the 80-90% level & the problems quickly reappear as the actual battery level is depleted.
The battery was replaced a year and a half ago & the 12 volt battery is good.
Help. The dealer is at a loss
