I guess I could have had worse problems. The IMA badge under the hood decided to fall off. Fortunatley it didn't fall out, so now I need a glue to put it back in place. Any suggestions?
Had the same problem here awhile back. I found the trick was to make sure the place where it goes is REAL CLEAN before you use the glue. Oily surfaces and glue don't mix :!: I used small dabs of super glue and it's held for 12 mths +
1 - 2 of 2 Posts
