Please post a link. Anything by the typical Honda kid is always very entertaining reading.Getshocked.ca said:That was the topic of the forum i saw this in
"I SAW THE NEW CRX SI"
and then there were 3 pages of speculation if it could have been a honda test car and finaly someone posted these pictures
Sounds like you bought yourself a real headache.vkykam said:Anyhoo, the car does have a salvaged title on it, was repainted from black to white, has a modified intake with a Apex fuel air controller, and supposedly a modified exhaust, and xenon headlights. Also of course is the cut-a-way wheel skirts and the CRX decals on the rear, both of which I'm hoping to get rid of.
Take it out and sell it on eBay. The S-AFC/V-AFC is designed to allow you some control over the A/F ratio by intercepting and modifying the values from the air flow meter (we don't have one) or MAP sensor. I've used them many times before and they work well. The V version allows Vtek switchover control.vkykam said:The Apex unit is a VAFC-II unit. As far as I know, it's wired and hooked up, but not programmed. The car runs fine from what I can tell. I have no clue how to use or program the VAFC unit, so I'm leaving it as is until I have the time to go through the manual, if I can understand it that is...
Aaron Cake said:Take it out and sell it on eBay. The S-AFC/V-AFC is designed to allow you some control over the A/F ratio by intercepting and modifying the values from the air flow meter (we don't have one) or MAP sensor. I've used them many times before and they work well. The V version allows Vtek switchover control.
Now obviously on a car like the Insight, you DO NOT want to be messing with the values coming from the MAP sensor, and there's no point in controlling the Vtek switchover point. No good can come of it and all you're going to end up with is a car that doesn't run right, kills cats, gets poor mileage and has constant CEL problems. This device was never designed for OBD-II cars, especially one like the Insight.
BLACK? Where'd a black insight come from? I want one.vkykam said:the car does have a salvaged title on it, was repainted from black to white,
ElectricTroy said:BLACK? Where'd a black insight come from? I want one.vkykam said:the car does have a salvaged title on it, was repainted from black to white,
Unfortunately you can't.vkykam said:I'm assuming I can leave the harness/connectors in place, and just disconnect the unit? I haven't looked at it to see how it's hooked up.
Thx for your input.
Guillermo said:I remember the previous owner posted photos on Insight central last summer, after he custom painted his Insight black.
