Hi Hou_ge2000:
What do you guys think of the Insight's CVT compared to that of the Prius design.
___I don’t really have a strong opinion either way. I like the HSD in its simplicity and probably longevity but I don’t like that it needs 2 MG sets and the ICE to transfer power through it (HSD as a system, not just the CVT).
Why did Honda choose to use a mechanical CVT rather than a more efficient one like that of the Prius?
___Probably cost? The CVT of the Prius itself is a marvel in simplicity but add up the surrounding components and it probably costs far more then the simple dual sheaved pulley and belt system of the Honda based CVT.
___As for efficiency, the Prius’ are darn efficient for the weight that they were designed at but as far as real world fuel economy is concerned, a CVT based Insight would probably far exceed the Prius’ real world mileage capabilities. The CVT however would not be a major factor in this. The 50% drop in weight and smaller frontal area of the Insight with a CVT would be. A closer match would be the CVT in the HCH vs. the CVT in the 01-03/04 Prius’. You can see the fuel economy battle heating up between the HCH’s and 01-03 and 04 Prius’ over at GreenHybrid’s Real Hybrid Mileage Database. An HCH w/ CVT is currently on top of the list with a host of Prius drivers following closely behind. All fall behind the 5-speed Insight’s by some distance and more then likely would fall behind the CVT based Insight’s as well. A particular 2000 5-speed Insight driver (Rick Reese) well known for his superb Insight fuel economy driving skills will probably soon surpass all of them with his used 01 Prius however.
Will Honda switch to using a Hybrid Drive like that of the Prius? rather than it's current IMA system?
___Probably not. The 2005 Accord Hybrid will supposedly use the IMA as is albeit even more powerful overall.
What benefit/disadvantage of each do you see?
___About the same as described above. The steel belt on sheaved pulleys is about as low cost an automatic transmission as you could probably find. The Prius’ CVT however appears on paper to be more bulletproof. The cost of the Prius’ CVT appears to be very cost effective in its own right as well but not when you have to have 2 MG-Sets and an ICE to propel the Prius as a system. I am not sure what kind of transmission the 05 Accord Hybrid will be using but since it is using the same 240 HP V6 as its EX counterpart, I would probably say it will use a std. bulletproof automatic that we have all come to know and love w/ the IMA attached at the front drive shafts somehow?
___Good Luck
___Wayne R. Gerdes
___[email:1289u8eq][email protected][/email:1289u8eq]
___Good Luck
___Wayne R. Gerdes
