1 - 1 of 1 Posts
Hi Guys, I have recently installed 5000k hid kit for low beam. I notice in dark night, I need to relay on ugly factory yellow hi-beam bulb to get extra light on road. I am planning to upgrade my high-beam to 5000k hid. But now the problem I am running into is that current OEM setup has drl and high beam in the same bulb. I am trying to achieve the highest possible white light in hi-beam and also not sacrifice with drl. So basically Hid that is not very bright in day (as drl) and same hi-beam hid I can use while driving in dark night. I have done some research and many people run into problems with hid flickering, error code on dashboard, etc... I hope I didn't get you guys confused. Your help will be much appreciated. My first preference is to go with hid, if that doesn't work then may be led, even if that doesn't work then just buy white hi-beam halogen bulb :(
1 - 1 of 1 Posts
