I changed my pollen filter today (and thanks to Figgy for his pics). I couldnt believe you had to cut the plastic to access it!
The foam on the base of the filter cartridge was slightly damp (not wet) - Is it a leak or just moisture from condensation from the A/C. Can the system be tested by a dealer to check for pressure loss?
Do I run the system on full heat to dry it out?
Thanks
John
Thanks
John
