I need 12 volts for my prius fan, 10 amp start 6 amp run at high setting.
Is there an always on direct to 12 volt battery connection in rear of car ?
or
A switched connection ?
Thanks
Linsight Designer
There is so much 12 volts back there it hurts. All kinds, every kind, come one, come all, get your 12 volts on.
Need lots o' current at all times ?: tap the DCDC's giant positive lead. You can't miss it.
Don't need lots of current, but still want 12 V at all times?: WHT/RED @ MCM pin B10 (there's only one back there with that pattern)
Need it whenever key is on?: BLK/YEL @ MCM pin A09 (there are other BLK/YEL, so make sure you've got the right pin)
Need IMA hold? (key on +10s after key off): PNK/BLU is your guy! There's two back there with this pattern and they're both the same... use either one.
Need 5 volts (and not a lot of current)?: GRN/WHT @ MCM pin C24. Make sure you pick the correct one.
Need something else? Post up and we'll find out.
