1 - 17 of 17 Posts
Can anyone tell me how to build an x-box green colored Knight Rider scanner and hook it to my Rostra Cruise control to make it variable. All the kits I've found are made strictly for the firebird and are not variable (or green) It is illegal to have red or blue lights in Florida. Thanks!
Discussion Starter · #8 ·
speed and specs
It'd be nice to have 10 LEDs and have them scan slowly at rest and get faster, but not rediculous, as the car goes faster.
Discussion Starter · #9 ·
speed attachment
Any idea how to connect the speed resistor to a Rostra Cruise?
Re: speed attachment
Easiest way would be to physically connect the pot directly to the cruise servo. There aremore elegant electronic ways bnt they get much more complicated.
Discussion Starter · #11 ·
servo
Let me see if I have the appropriate components and if so, I may just ask you about the servo. first things first. Thanks!
Discussion Starter · #16 ·
MIMA software
Does the MIMA software allow me to modify the IMA setting so I am guaranteed at least 70mpg in 5th gear. (higher cut-on threshold)?
Getting OT but.
Yes It allows you to modify the IMA settings, but without considering speed, battery SOC, terrain, and the many other conditions that control the actual MPG you can get, It is not possible to gurantee anything except that based on the other users, it will improve your MPG. The amount of improvement is up to your ability to use the new capabilities to their best advantage.
Best read through the MIMA thread.
http://www.insightcentral.net/forum/vie ... 57&start=0
Also
http://www.99mpg.com/
1 - 17 of 17 Posts
