KSPORT's Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
Kontrol Pro
•36 levels of adjustable damping
•Made from high quality 6061 aluminum with T6 for increased hardness
•Compression/Rebound adjustable
•Adjustable spring perch for height adjustment
•Adjustable body allowing maximum suspension travel
•Pillowball top mount with adjustable camber (not available for some models)
•Monotube high pressure design reduces oil leakage
•Electroplated body for protection from corrosion and rust
•One year limited warranty
2010 ~ 2012 - - Height/Ride Adj - 36 dampening levels - Uses Fr OEM Mount / Uses Rr OEM Mount
Rally Spec GR (Gravel) or Rally Spec AR (Asphalt)
•Special designed springs for rally conditions
•Extended Piston Stroke
•Reinforced internals to withstand extreme track conditions
•Made from high quality 6061 Aluminum with T6 for increased hardness
•Compression/Rebound adjustable, Adjustable spring perch for height adjustment
•Pillowball top mount w/ adjustable camber (not available for some models)
2009 ~ 2012 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Uses Fr OEM Mount / Uses Rr OEM Mount
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Coilover Systems
Will this increase the weight capacity?
@ 200 lbs, if I get a like sized buddy, I'm over reccomended capacity.
You will removing the OE shocks & springs. There will be little if any weight difference.
How is the ride? I've rode in two different cars (Integra&TL-S) with K Sports and the ride was ruff. How much?
Most put on coilovers and make them "racing stiff". They have 36 levels of damenign adjustment so you can make the ride how you want it.
